Hi there
We've run on Subaru WMI(water Methanol Injection),we've run AEM WMI kit which has been very easy to fit and you should be able to fit this very easy and power gains 15bhp which is lot less than we are expected,when we are run only methanol in tank(15-20%) we are gained extra 40bhp
WMI is not for making more power(but yes you will make bit more power on the top),is more for cooling the IAT/ACT(Air Charge Temperature) and bit more power,we are tried several settings of injection or we are tried several other mixtures(60% meth and 40% of water or 50/50 etc),gains has been still same around 15bhp,but agree our ACT dropped on drag strip to low 35C during the very hot weather(without the WMI our ACT has been at 60C)
If you are looking to making more power then I would highly recommend to run meth in tank(15-20%) and make two maps one for normal and one for meth fuel,gains are much bigger on supercharged or turbo cars,we are made on V-power 352bhp and on Meth we are made 382bhp
Fail safe you shouldn't need,but depends on the yours feel and what you want,just don't expect this will make running WMI safer,depends on what nozzle you want to run,but we are run bigger and smaller and we are gained exactly same on our WMI around 15bhp,but with lower ACT/IAT temps
Hope this helps
Thanks,Jura
I'm running a Jrsc 6-7 psi currently
Toda manifold
Solid fab 3" cat back "no cat"
Rc650 injectors
Tegiwa M
I'd like to get 340 but i won't up the boost till I have adequate cooling to which you have just given me my answer, I'll run an aem kit, my boss has loads of methanol, so I'd like to say I'll run meth all the time. And go for there
