Over the last couple of days, I noticed my CTR was pulling to the right, and I needed to hold the steering wheel off center to the left whilst driving straight. This is a little strange as I havent hit a curb, pothole etc... I guess its just down to the particularly bad roads around where I live.
So today I went down to a tyre center in Plymouth to have a 4 wheel laser alignment. The quoted cost was very reasonable - £5 for just a check and printout, and £45 for a check and adjustment where needed.
My results were ('= degree symbol);
Front Left;
Camber -0'47
Toe 5.0
Front Right
Camber 0'20
Toe 0.1
Rear Left;
Camber -1'29
Toe 0.1
Rear Right
Camber -1'04
Toe 1.2
Now the big problem with the above concerns the front left wheel. The toe is way out, which explains why it was pulling to the right. Also the camber is out.
The fact the camber is out is a problem because the front camber is non adjustable. With this in mind I did not have anything corrected (so cost me only £5) as I am going to show my Honda dealer the results and see what they have to say. I presume they will want to check it themselves, and if it is outside the factory tollerances, I guess it will be rectified under warranty along with a 4 wheel alignent (hence I didnt pay to correct the toe today).
Does anyone know the tollerances for the front camber?? I have read the rears can be up to -1.5?? I guess the fronts would be a lot lower??
If Honda decide they dont want to rectify it under warranty, I guess I will have to go down the route of front camber bolts to allow adjustment and a 4 wheel alignment.
I am also considering getting the camber bolts anyway, and getting the tyre center to adjust the settings to a 'fast road' spec. I found this quote from ABP;
So for the fast road set up - I only need the front camber bolts?? I guess the rear camber arms are only needed if your rear camber is out from factory, and I believe mine are ok.
So finally, can someone tell me the settings for the fast road spec - So if I decide to go down that route, I can fit the camber adjusters and then get the tyre centre to set it up to fast road spec for their charge of £45.
Any help much appreciated. :)
Front Left;
Camber -0'47
Toe 5.0
Front Right
Camber 0'20
Toe 0.1
Rear Left;
Camber -1'29
Toe 0.1
Rear Right
Camber -1'04
Toe 1.2
You will need the front camber bolts for sure (35.00 inc vat pair) but it really depends to what degree your rear camber is out of spec whether you will require the rear adjustable camber arms (150.00 inc vat pair). In our experience (quite vast ) only about 20% of cars actually need the rear arms fitting.
