Just seen this thread so sorry for delay but it could be the air mix control linkage door not opening correctly.
Try the blower diags procedure and see if it gives you an error code.
Procedure below :
How to Retrieve a DTC
The heater control panel has a self-diagnosis function.To run the self-diagnosis function,do the following:
1. Turn the fan switch OFF.
2. Press and hold the recirculation control switch and the rear window defogger switch down.
3. Turn the ignition switch ON ( l l ) .
4. Release both switches.The recirculation indicator and the rear window defogger indicator come on. The
recirculation and indicator goes off 3 seconds later and the AC indicator comes on. then the self-diagnosis
will begin.
About 10 seconds later, the self-diagnosis will finish and the A,/C indicator goes off.
.lf any trouble is found. The recirculation indicator blinks the diagnostic trouble code(DTC)to indicate a faulty
circuit.
lf the system is OK ,the recirculation indicator stays off.
Fault codes :
In case of multiple problems he recirculation indicator will indicate only the DTC with the least number of blinks.
ln case of an intermittent failure, the heater control panel will store the DTC until the ignition is turned off.
Detection Blinks, what they mean :
7 An open i n the a i r mix control motor circuit
8 A short ln the air mix control motor circuit
9 A problem in the air mix control linkage door or motor
10 An open or short in in the mode control motor circuit
11 A problem in the mode control linkage doors or motor
12 A problem in the blower motor circuit
13 A problem in the EEPROM in the heater control panel;
the control panel must be replaced
14 An open in the evaporator sensor circuit
15 A short in the evaporator sensor circuit.
HTH
