Arb drop links
Hi guys is it Worth buying some rear drop links if I'm changing the rear anti roll bar
Sent from my E6653 using Tapatalk
If your doing the arb you may as well do the droplinks at same time as they are cheap enough and a doddle to fit, would be daft not to I suppose.
Also upgrade the arb bushes to polyurethane ones while you are at it, powerflex or similar (they are cheap on carparts4less at the moment with a discount code. - they are under the performance section)
