Back firing
It used to happen every now and then but now its doing it quite a bit.
Whenever I let my foot off the accelerator quite a bit, it back fires and popples.
Could this be my timing out or something? :?
Is it anything to worry about?
Nat - I know some motors do it as a natural thing, but if it's starting to alarm you mate, you'd be better off asking on the DC2 forum :wink:
Just in case you don't have it to hand.... www.itr-dc2.com
already have!!! :p
Are you running a de-cat or non-standard induction?
Sounds like overfueling to me, normally just the ECU dumping too much fuel into the cylinder, it might be an air mass flow meter sensor that has died/taken a knock.
Yup de-cat.
Both Exhaust and induction kit in HKS.
About 6 months ago my vtec controller was re set up due to something not right on it and it was idling too low. That was all rectified though.
Do I just need my ECU checked out then do you think?
SOates82 said:
:? Might be worth it. It could identify if it is a air mass flow sensor thats gone iffy.
erm what does that mean?! :oops: :?
easy to fix? a little prob?
The collar that has a couple of wires coming off it just after the cone from your induction kit is the air mass flow meter mate. If it's gone bandy then yoy may need a new one.
Not difficult to swap over I don't think Nat, Benny Boy will have it done in double quick time :wink:
