Bearing annoying noise
Hi in getting that annoying bearing noise on my ep3 type r
its only when it's cold until it's warm it's coming from the alternator pulley area,do you think I should just change both pulleys and replace the belt
thanks guys
It'll be more of a wear and tear problem than a common problem. Bearings wear out, its normal.
Just a word of warning, when I changed my top pulley the crank pulley was on its last legs too. Would be worth inspecting that whilst it's all apart. It was a Honda only part and they don't keep it in normal stock. Cost me about £100 iirc
thanks guys
Check my post mate I have similar issue and have found out what it is.
My top pulley was making noises, so ordered a replacement. When we went to fit it we found the other one had play so ended up changing that too. Got the parts from Tegiwa.
