Than this is what you might want mate!
Powerslot Plus Big Disc Kit Civic Type R EP3 FRONT 348mm
Power Slot Plus Big Brake System uses a larger diameter, premium quality Power Slot brake rotor combined with your original factory brake calipers. Power Slot's patented caliper relocation brackets space the factory caliper further away from the hub to accommodate the oversized brake rotor. This increases brake torque force without affecting pedal effort or travel.
The larger rotor is also a more effective heat sink, absorbing the heat generated under heavy braking. This greatly reduces brake fade and provides consistently shorter stopping distances, up to 33% on select applications, especially from higher speeds. By retaining the factory brake caliper but increasing its effectiveness you are able to have an affordable big brake solution.
Power Slot Plus – Key Features:
Premium quality, larger diameter Power Slot brake rotor with Vac-U-Slot technology designed to evacuate gasses and dust, shed heat, and keep the brake pad surface cleaner
100% bolt-on system
Relocates the factory brake caliper for increased braking effectiveness
Rotors are Cadmium plated to protect against rust
No special brake pad sizes required – just use an original equipment-sized high-performance pad (sold separately...please see brake pads section)
Complete hardware kit and comprehensive installation instructions included
All Power Slot Plus brake kits require the use of larger diameter wheels – check the dimensions of your wheels carefully before purchasing.
OE Size: 300mm
PowerSlot + Size: 348mm
Application: 01-06 Civic Type R EP3 FRONT(you can also get rear ones too)
Price: £380.00 Includes VAT
http://www.hondaperformanceparts.co...lus_Big_Disc_Kit_Civic_Type_R_EP3_FRONT_348mm
