You checked the brake fluid levels in the reservoir?
Double check the vacuum line that goes to the servo and make sure that's not split. When you turn the steering wheel (without pressing the brake and stationary) does the engine rev up a little? It should rev slightly as it's under more load.
If the engine tone changes that's fine.
The vacuum line, just look at the servo, there's only 1 hose that comes off it, it will go to the inlet manifold. It shouldn't have any T-pieces or joins etc. If you want to test to see if its split, get some washing up liquid and water in a spray bottle and spray on the hose, if you see bubbles it has a leak.
I was going to mention the cigarette thing, or E cigs as they give of plenty of vapour :lol:
It's not a brake fluid leak you have, assuming the fluid level is fine on the master cylinder reseviour.
Deffinately check the servo for operation by doing what Eddie said with starting the engine. I had a look today on my own engine, the vacuum pipe which comes from the servo isn't very long at all and goes into a metal joiner where its clamped on.
