The Post Facelift cars aren't safe either there have been a few go as well. Basically a badly built gear box IMO It's like Honda spent a fortune on the engine then just found a gear box lying around the workshop and modded it for the ATR
Crunching going into 3rd and 5th. Then it will stop going into reverse completely.
You are looking at between £600 - £1000 to repair it.
Thanks for that, should be relatively easy to check the change into third, I guess the change into 5th may occur at slightly illegal speeds if you're pushing it. I would imagine that the wear is more down to how careful you are changing gears rather than the way you drive the car (aren't they supposed to be thrashed
£600-£1000 doesn't sound too bad if the worst happens though.
