Hello all
Symptom: when starting the car from cold it turns over but really struggles to fire and i have to apply some throttle (10-15 seconds or more) sometimes (left over the weekend then Monday morning start) it doesn't start at all, it just turns over and and doesn't quiet fire even with jump leads or bump starting :-(. It took me and the mechanic from the garage 40mins to get it started on Monday morning which involved numerous amounts of unplugging the lead to the fuel pump then turning it over to dry off the spark plugs. (and connected to the jump leads all of this time)
Recently just had new clutch, radiator, spark plugs, oil filter and change. Once it finally fires from cold it sounds like its just missing a little bit for a couple of seconds if that, then its absolutely fine. The car runs absolutely fine and when i stop when its warm and re-start it, it starts fine straight away. There is no EML and the thermo sensor has been replaced. Idle control valve is also clean and working fine.
Properly confused, and not enjoying getting up for work and wondering if the car is going to start or not now.
Any ideas anybody?
Any ideas anybody?
