I have recently purchased an EP3, on which I put my other set of wheels with summer tires.
After that, the car started pulling considerably randomly left or right, I have to forcefully keep it straight otherwise the car would steer into the other lanes. With the other set of wheels and winter tires, I did not have this problem on the same roads.
I have checked tire pressure, swapped the front ones with the rear but the problems still persists.
I have also changed front brake pads recently, which were rubbing a bit in the first few hundred kms, but I doubt they would cause the pulling, since the car was steering perfectly with the previous set of wheels.
Is it possible that different sets of wheels need different front end alignment or could there be some other problem?
Thank you for your answer!
