Charged ep3 clutch choices
Evening troops ,
I have a JRSC ep3 which is now needing clutch done. I have LSD ready to go in but unsure which clutch to go with. Will be using it everyday but not bothered about use-ability really. Was going to do the shifter bushes to.
Thank you in advance
Exedy stage one with OEM release bearing :smt023
I wish I'd have gone with this clutch. I have a stage 3 copper ceramic 6 puck effort. It's not so heavy as to be uncomfortable but it is a bit on/off when in traffic.
OEM release bearing is a must, most of the aftermarket ones just don't seem up to the job.
If you are doing the clutch, it might be worth thinking of a lightened flywheel as well. Although I do find my car jerks you forward a bit with engine breaking when coming off the throttle under 1,500 rpm in 1st and 2nd. Spins up a hell of a lot quicker though.
Thanks guys.
So order bearing from Honda, the Only bit I'm not sure is which model of exedy. There seems to be a load of different part numbers coming up for me. That pretty much look the same.
Any help for a cheeky chancer ?
