Right - Although I regularly check and keep an eye on engine oil levels, I am guilty of never having checked the coolant level. Looking in my owners manual, I have read the 'How to check', and 'How to top up' (and with what).
My level in the 'Engine Coolant Reservoir' is about 2cm above the minimum mark. I guess this means it will be ok to top it up closer to the maximum level. The level in the radiator is full to the filler neck under the radiator cap, which is ok, as described in the owners manual.
The manual says to use 'Genuine Honda All Season Antifreeze/Coolant Type 2'. Which is a pre-mixed 50/50 fluid. Is this necessarry?? Does anyone else use an alternative?? Does anyone know the quantity you buy it in and what sort of price??
Also I presume from the manual you fill the coolant level directly through the 'Engine Coolant Reservoir' which is the smaller plastic capped tube, between the washer fluid and radiator. Does the level in the reservoir and radiator need to be topped up independantly, filling one wont push up the level in the other?? Also do you use the same coolant in both cases??
Any help appreciated, cheers.
