EP3 clicking noise rear of my 54 ep3
Okay, so I've had this clicking noise on my car for a while cant seem to find any threads on it...
Only seems to happen when I'm pulling off, or if I stop and reverse a little..
Any ideas?
Drop Links? Brake pads moving on the sliders? Loose subframe bolt?
Sound travelling through the car and it is an engine mount or top mount?
Hard to say from that description to be fair. Could be anything that is load bearing or rotates.
Safest thing to do is pop it down to your preferred garage and have them check it out. There's not a lot at the rear of the car likely to cause that sort of noise, maybe brakes worn low and the indicator part is starting to hit the disc or a wheel bearing.
Cheers guys,
just been for a drive it happens all the time when driving going over bumps etc..
Sounds like the right rear but its so hard to tell.
Its defo a click metal on metal type of noise, also have a little squeak noise sounds like rear shock also.
