Hi all,
ive recently put a new clutch in my ep3, it's a lot smoother now changing gear but the bite is still on the floor. I've bled and changed the clutch fluid, it did make it smoother between gears but it's still not right. I have trouble getting into first at times.
I drive about 10 miles to work and in the morning with no stop starting in traffic it's pretty good to within a mile or 2 of work when I hit traffic. Which is when it starts to get hard to get it into first gear to pull off (sometimes I pull off in second because it doesn't want to go in firs).
On on my way home when I hit more traffic (a lot of stop starting) it gets really bad, almost impossible to get it into first gear.
When I pull up on the drive then I try putting it in 4th for example while stationary and the car jumps forward as if the pedal is not fully depressed.
im thinking master cylinder, has anyone got any advise or other ideas before I change the master cylinder!
thanks
thanks
