Hi I was changing the clutch fluid on my ep3 and by accident I let some air back into the system.
I was using a one man bleeding kit with a valve in the tube so air cant get back in. However when I was pumping it fell of the bleed nipple.
Anyway now I have no clutch pedal. No pressure at all just goes straight to floor unless I pull it back up.
I suspected that I may have damaged the seals on the master cylinder and so replaced it with a used one of integrastella of ebay. I then bled it again but still no change the slave and master don't have any leaks and no air comes out of the slave when bleeding it just trickles out fluid when opened.
Please help !
Please help !
