I'm after a bit of advice with an issue I'm having with my type-r.
When I start the car from cold (no problems starting)the engine judders and lacks power to the point of nearly stalling at times, its a similar feeling to that of running out of fuel!!
The issue occures when the temp gauge needle is on roughly1/4 of the gauge, and all issues stop when the engine is up to temperature.
The issue is most noticeable when the engine is sustaining around 2500- 3000rpm (i.e. 30mph in fourth).
To stop the problem I have to take the engine up to around 5000rpm (drop a gear or speed up!!)
I've changed the spark plugs as it's a cheap option but made no difference, my next thought was to buy a coil pack and change each one, one at a time to see if that makes any difference. After that I'm not sure...
has anyone had this issue or have any ideas on what it could be?
Sent from my GT-I9300 using Tapatalk
