Hi guys.
Had some work done on my car at Holdcroft Honda in Stoke-on-Trent:
Valve clearances adjusted, new rocker cover gasket
Brake fluid flushed/changed
Air filter changed
Pollen Filter changed
Removed driveshaft heatshield
Gearbox oil changed
Visual check of chain/tensioner etc
And removing the rattly heatshield has uncovered new noises
First of all the engine was much quieter, 2004 EP3, on 71k, clearances hadn't been done since 25k it seems! So yep, much quieter, smoother, less tappy at tickover and through the revs.
Thats lasted a week and tonight after work sounded a bit tappety again... could just be injectors I suppose but basically what I am asking is how quiet/smooth should the engine sound once the valve clearances have been done?
Secondly this could have been like this for ages but I was doing something and put my foot on my clutch before pulling off the other day and after holding it down a few seconds the car got quieter.
Seemingly when the clutch is out you can hear a light whirring, not that overbearing at all, which goes away a few seconds after holding clutch pedal in and returns when you release.
Standard original clutch... could it be simply the release bearing? It is getting a little stiffer getting into gears when on the boil but otherwise the gearchange is nice and smooth, slick and positive as it should be.
Thanks folks, I am probably worrying too much really but it's cost enough already, wanna get it lowered instead of maintenance now lol it's had loads done since I bought it 8 months ago.
Dave
Air filter changed
Gearbox oil changed
Dave
