MilanoChris said:Are you sure that running an oil with such low viscosity is a good idea?
CTR said:MilanoChris said:Are you sure that running an oil with such low viscosity is a good idea?
Honda recommened using Castrol SLX Longtec [0W30] so it shouldn't really be that much of issue. Each to their own though.
MilanoChris said:CTR said:MilanoChris said:Are you sure that running an oil with such low viscosity is a good idea?
Honda Germany strrongly reccomend not to use it as they've had a lot of engine's go due to the oil being consumed to fast. They recon it's too thin for the high revs and believe 5W30 is a much better option.
I'd listen to them, German engineers tend to know what they are on about.
SpaceMonkey said:I recently purchased 10 litres (2 x service oil) of Silkolene Pro S 5w40 from Oilman on a GB on here.
This is meant to be pretty crap hot :wink:
Think it is still availible, might be worth seeing if you can order it & receive it before Friday :wink:
HTH
Composite Guru said:MilanoChris said:Are you sure that running an oil with such low viscosity is a good idea?
I used to run my S2000 on the stuff Chris and never had a problem, just depends if your car drinks oil from the start, mine never has.
In a hot country i would use a higher one but this place is ok IMO.
I check my oil regularly so if i see it disappearing fast then i'll go for something thicker.
