No, fair play to you fella. I can see what you're talking about. It's just your "a box is just a box" comment seemed a little naive.
I'm genuinely interested in this experiment and I'll be keeping an eye on it to see you progression.
People do go as far as putting those screws in, and knife edging the butterfly. Althoug it's a lot of effort & you will see minimal gains, if any.
Bored out throttle bodies from Spoon etc are tapered. If you're going to bore the whole thing, then you will need to port match the enterance on the inlet manifold, otherwise it's a waste of time.
I was told about someone who had a full engine build, fitted those shorter screws on the butterfly, went for a drive, a screw got loose, went into the engine, and destroyed it. Locktite FTW.
I will try and get some scans for you if you're interested?
Idle was really low nearly stalling the engine?
Sounds like it's starved of air, and now running rich.
Too bad I have to cross the channel to get it dyno'dOK, that shows the car has noticed a change. Best get it on the dyno to make sure it's a good change.
