Please read the above post. Tried that, didn't work.You could put a higher wattage lamp/LED in it that would make it brighter as long as it was 12v dc
I've noticed before if it lights up or not on mine.
I do know that if you press it while its already running, its makes a terrible noise.
:lol:
It's the same as turning your key back to stage 3, it re-engages the starter motor...
Never tried it in my FN2, which I think does light up by the way. With the lights.
LOL, Mine has 3 wires, is it wired using a relay? from memory i think there is a ground, phase/live in and then a trigger out for the relay. It is defiantly a genuine Honda one as well.
I can pull the gear stick surround off and take a few pics if you like if it would be of any help?
They do light up, but as already stated they are very dim. I've tried changing the LED in them but that doesn't make any difference. I'm guessing it's because it's run from a 12v power supply, but I know very little about leccy, so I could be wrong.
It doesn't re-engaged the starter on the FN, i've tried it... :lol:
As for lighting up, the writing lights up red before you start the engine and once started it slowly fades out which is a nice touch imo.It does this lights on or off.
