Ok great, but suspension geometry is not the same as corner weighting. I would suggest having it corner weighted as that will also make a huge difference in how the car behaves. Corner weighting will basically set up each corner of the car with different spring rates (and dampers if you can adjust) in order to give it a better weight distribution, 50/50 being optimal. What will happen when you remove weight from the rear is the rear springs will become too stiff for the car and create an imbalance between front and rear, putting more of the weight onto the front of the car. They need to be softened up to bring some of the weight back to the rear of the car and spread the weight more evenly. That will give you a much more stable car and a faster lap time too.
