my drivers card does the same mate.
i have narrowed mine down to the card vibrating on the edge that touches the metal on the door and will be putting on sum single sided sticky foam strips i have this weekend to see it solves the problem.
appologies once again scouse, it wont happen again.
Had the same problem and had the same thought as you, so put a bit of super glue on the end of the panel that viabrated against the metal and that cured it.
Going to have a go at mine this weekend did you just use superglue? Where did you put it at the top left corner of the door card nearest the drivers door mirror? or all the way up?
I wouldn't use superglue fellas, if you need to remove the doorcard in the future to repair electric windows/door handles/central locking etc, it will be an expensive job. £150 for a doorcard IIRC
Did the door card fit back on no problem? And did you snap any of the white clips?
How much was the insulation strip? No rattles at all now?
