I joined this thread exactly, because we've had E10 for almost 2 years now. So i do have quite a bit of first hand experience, and I hope it can be helpful. I have no idea why any website or media source would scare people, by saying, that ethanol is bad for performance cars, while in reality, it's the opposite. I'm sure none of them used E10 before, but I've been using it for quite a while, in multiple cars, NA and turbo, no problem anywhere. I'll give you an example: many high performance drag cars in the US are made and tuned to use E85. Why? Because ethanol has a higher octane number, which is great for boosted engines, and it also burns cooler, than petrol. Yes, you need to use a bit more, because of lower caloric values, but who the hell cares on a drag strip, or racetrack, and on the other hand, by blending in 5-10% its not even noticeable. All in all, ethanol is not worse for performance engines, it's actually better.
Furthermore, I am in Europe too, only quite a bit to the south-east, but we have pretty much the same car market, the only difference may be, that Vauxhall is called Opel here. Same mix of cars means same type of fuel, as for the entirety of Europe. Why would the UK government give you something worse, that cannot be used by the people? It doesn't make any sense. Of course, the US and Australia are quite different in this regard. (I can't imagine filling my car up with 88RON)
Finally, regulations are set in stone. If something is called 95RON, it is 95RON period, no matter the contents. I can only repeat myself, many FK2s and FK8s here have been running E10 95RON for 2 years now, with no problem what so ever. They were made to run on 95RON. It's strange from Honda to say, that anything below 95 will be destructive to the engine. Yes, I'm sure the regular 88RON in the US would be destructive, but 94? Don't think so. I think the ECU would just add a bit of delay on the ignition timing, and maybe reduce boost a bit, to avoid knocking, and lose a tiny bit of power. Yet again, I'm so sure, that the UK will have E10 95RON, that I would bet my car to be taken around the Nürburgring by someone :)
