Hi, i realise its near impossible to diagnose an engine noise via a thread, however im after advice and if anyone has ever come across what im experiencing with my ep3. My car has covered 101,000 and i change the oil every 3000 miles with castrol edge 5w40 and owned the car for over a year now and check my oil once a week.
Basically i got a little over-excited the other week and down-shifted into 3rd gear a little too early when slowing for an upcoming corner and i saw the engine rev just over 9000rpm. I instantly realised id massively f****d up and this was not going to end well for me. Anyhow i pulled over shortly after as i heard a noise from the engine (great) i then limped the car home slowly and left it until the next morning. From cold start up a rattle could be heard for around 1 second then disappeared. Once the engine is warm and up to temperature the rattle can be heard at around 2500-3000rpm, but is not very loud, when driving the car the rattle is alot louder and can be heard at around 4000rpm upwards. Vtec engages as it should and everything feels the same with the car power wise. The "noise" i would describe as a "rattle" and not a "knocking" sound which draws me to think ( & pray ) i have just destroyed the timing chain tensioner causing it to rattle just when oil pressure builds up. Or could it be far worse and have spun a bearing ? The noise just doesn't sound like a bearing, its not there all the time which is what id expect if it was a shell, its not developed into a louder noise either but obviously it needs sorting either way.
Am i wasting my time fitting a new chain kit ? or do i just buy a second hand engine ?
Any help or advice is much appreciated.
