Exhaust Bolts (not spring!!!)
Hi, just recieved my Toda Cat-back for my EP3, exhaust comes with no gaskets or hardware. I have ordered 1xDonut Gasket, 1x3 Bolt Triangle Gasket, 1x2 Bolt oval gasket and 2x Bolts with spring assembly. I believe there are 5 more bolts in the catback assembly that are just normal nut and bolts. Does anyone know the size of these, I've done a search already and found nothing, only info on the spring bolts. Any help would be massively appreciated.
I know of the two spring bolts on the back box.
There are three bolts for the cat to b-pipe section.
Is the oval gasket needed if you use the donut ring and spring bolts?
No mate, I have a 2 piece B pipe so I've got an extra gasket and 2 bolts
I believe you have the Toda Power Flow exhaust system
There be 3 nuts and bolts along with flat triangle gasket that fits to the cat
2 nuts and bolts along with oval gasket
And dougnut gasket and spring bolts for back box
