oh i see, my pedal doesn't visually lower when engine is started though if thats what you were thinking, just the softness and biting point when physically pressed!
think the lipped disk may actually be effecting it, i braked hard today to test it again and when i got out i could see the pad was glazed on the disk but only around the inner side, not the outer side were its worn/lipped a bit so pads probably haven't been bedded in fully either!
could this be causing the issues??
its long now to take them all out and file down! but main thing is the braking is better than stock before and feels safe! how many miles do you think it will take for the pad to wear in to the shape of the disk??
New pads on old disc would feel slightly spongy, did u file the edges of the pad ** fitting? do this if u have 'lipped' disc.. cause if the disc is lipped, your new pads are only in contact with the lipped bit.. not the full surface of the disc.....
