Fk2 Type R Airbag light on.
Hi all, need some advice with finding the location of an airbag connection.
Light on dash seems to only come up when passenger front seat belt is not connected.
Message on scanner reads
open in the front passenger airbag second inflator.
I'm guessing this is under the passenger seat?
Thanks in advance
It could be where the seat has gone backwards and forwards the yellow connector has come loose, if you cant see well under the chair, remove the front 2 bolts and tilt it back and make sure everything clicks well into place. My celica used to always do this and this fixed it assuming its the same issue! Disconnect the negative, goodluck
