May as well be listed on here too as more FN2 owners are coning onto the forums.
Firstly, open both doors and try pressing window down for 10s, followed by window up for 10s. If that fails, try the full procedure:
1. Turn the ignition switch ON (II).
2. Move the driver's or passenger's window all the way down by using the driver's window DOWN switch.
3. Open the driver's or front passenger's door.
NOTE: 4-7 must be done within 5 seconds of each other.
4. Turn the ignition switch OFF.
5. Push and hold the driver's or passenger's window DOWN switch.
6. Turn the ignition switch ON (II).
7. Release the driver's window DOWN switch.
8. Repeat 4-7 three more times.
9. Wait 1 second.
10. Confirm that UP AUTO and DOWN AUTO do not work. If UP AUTO and DOWN work, go back to 1.
11. Move the driver's window all the way down by using the driver's window DOWN switch.
12. Pull up and hold the driver's window UP switch until the window reaches the fully closed position, then continue to hold the switch for 1 second.
13. Confirm that the power window control unit is reset by using the driver's window UP AUTO and DOWN AUTO functions.
If the window still does not work in AUTO, repeat the procedure several times, paying close attention to the 5 second time limit between steps.
