Front Honda Badge install on Honda Civic FN2?
Hi guys just recently purchased a front badge for our Honda civic fn2. was just wondering if anyone has a guide on how to fit it? does it screw in or just stick on? Many thanks Mark
Sorry, just been watching the GP on delay.
It should be on a sticky pad with two pins that run through the grill with a push nut on each.
Easiest way is to take the grill off unless you have small hands!
You've already got the badge so no worries. If it has the pins on it, you should be able to reuse the push nuts from the old badge if you are careful getting them off. If not then they are part number 90301-ST0-003, list price is £1.82 at the main dealer.
The "Type R" badge is on threads, big plastic washer and nuts through the grille.
H badge as above, remove the push nuts and pull the badge off from the front.
Both easier with the grill off the car.
