Front lca bush removel ,advice wanted
Iv spent most of my Saturday on this one arm. The big bushes are fairy easy to get out abit stuck on the other.
Dont need a torch either.
I used a press to get the rear ones out.
the oem rear ones came out quite easy and i didnt have to use a saw or anything.
Very true but I don't have a press and local garage will charge me , iv got them out now and was pritty easy overhall anyways ,ganna give em a splash of paint while I wait for the bushes to arrive.
On another note I want to remove the air con. I can get a non a/c belt easy, but not sure what else is involved or needed.
Apart front the belt you don't need anything. Pretty straight forward job imo.
i removed my Ac also and the most effort was getting enough space to remove the AC-pump behind the radiator.
In the end i removed my radiator which made the job quite easy.
Gold Barr update - bush's arrive Monday
seriously is just the belt needed and should bolt straight out ?
is it possible to get the a/c unit out keeping the rad in place ?
