Help, front left wheel cambers out at the top, no obvious damage or anything bent, had it inspected by two different garages .. Up on the ramps.. Both say they can't see anything wrong.. I've had a good look myself, possible bottom arm is bent, because I can see two paint cracks, or maybe it's the ball joint.. Or the suspension shaft.. Now the ball joint looks like its fixed to the hub.. Is it ?? It's only cheep to replace, so I'm going to replace that (if I can) before I move on the the bottom arm, then the strut .. Has anyone else had this issue ?.. 04 plate facelift
