FRSU question
Sorry to bring this one up again but I've just got from having a full laser setup.
I told him to set it to........
1 deg. neg. allround
1 mm toe out at front
1mm toe in at rear
He then asks me is it 1mm total toe out or per wheel
Same at the rear ? to which I said not sure ????
I ended up with......
.54 deg. neg at the front both wheels
.54 deg ns rear, .48neg os rear
.9 mm toe in both sides at rear
.6 mm toe out both sides at front
Should it be 1 mm total toe out or per side ?
Same at the rear.
I always took toe per wheel not both sides. He's not done as you asked on the negative camber either.
I've heard good things about centergravity. You'd certainly not be going back to get it rectified.
Went back to Jeff Fowkes today and asked about the set-up. When I asked him why he'd not set the camber to 1 deg neg like I asked he replied he had. ! What I thought was .54 neg (half a degree) was actually 54 minutes, just shy of 1 deg neg. 60 minutes equalls 1 degree. Walked away a little embarrassed.
1 degree neg camber all round
2mm toe in at rear
1mm toe out at front
These settings are taken from the suspension explained thread.
Regarding the toe settings......are the they total toe or each side?
