love what youve done so far matey......as for the steering rack riser
i have one to fit atm too....got any tips also what size spanner was it to remove the steering arms
Skunk 2 lca look naughty but its too much for bling
however im tempted to order some now though
thanks for the feedback, the skunk arms are a lot lighter than the stock ones so they do have a purpose. However performance wise there are far more items which will give you more bang for buck. They are fantastically built though and do look nice so I figured with me spending around 2k on parts with me fitting to save the cash I may as well fit something you can see!
The rack riser was a bit of a pain if I'm honest, the hardest part is deforming the locking washer due to terrible access. From memory the spanner was 30mm, the shorter the length spanner the better. The easiest method I found was to completely remove the airbox and steer the rack so the bracket was nearest the passenger side.
Small update on the car, trying to get the car set up to my driving style one step at a time and I needed to try change the characteristics a bit. It was being a bit skittish on the front so I lowered the front about 20mm more to put more weight on the front end to try reduce this. This was successful and following this I went from 0.5 degree front camber to 1 degree to assist the grip. Car feels much more planted now and a little more liveable. I'm never expecting the car to be comfy at all with this set up, it will always be very hard and unforgiving. It's a bit of a project for me and will be attending trackways when I'm more comfortable with it.
Pic of during set up
also fitted this due to never ending issues with my aircon which I never mentioned, Found the culprit to be a tiny leak in the front pipe after a bit of investigation with some dye and fitting a seal to find the leak was some corrosion close by.
anyway I fitted this to find that since determining the cause of the leak I now have a hole in my condenser from driving around while the pipe was on order, damn stone wedged into it! I now have a new condenser on order which I will fit shortly
