Car: 2007 fn2 type r
Done approx 600 miles on a cclutch stage 2 and quaiffe lsd. Had the expected running in issues with the clutch and it's all settled now.
Now I'm experiencing gear changing problems. When the engine is cold the problem isn't there. However once a few miles have been clocked up all the gears become hard to select. 1st being the worst. Have to double clutch at times or engage 2nd then 1st. It's almost like when the clutch pedal is pressed, it's not releasing fully.
When tdi north did the work they said the clutch biting point has been set low as to take away pedal travel. They said this can be adjusted via the pedal box. So I'm going to let it out a half inch to see if that helps engage the clutch fully. Also going to check gearbox oil is ok.
Other than that I'm out of ideas. The clutch isn't slipping so no issue there. Possible pressure plate failing? Or could it be that the gearbox is on its way out?
