Hi All , Had my typre R a few weeks now so just trying to get to no more about them. Was a light knock on the rear which was the drop links which is now sorted.
next job is to remove the light rattles, Going to check all the suspect ones ive read about on here, Manifold covers, drive shaft cover and so on. Always seems to be one around 3-4k in most lower gears.
noticed the clutch peddle/Bite point is low but after reading on here seems to be common, about an Inch Up from the floor. in 1st and 2nd gear i notice at low speeds almost like a whine from the Gearbox i belive but not sure if this is common but hope to no more once the rattles and vibrations are gone.
Can anyone let me no if this is normal on CTR's?
Cars on 93000, Serviced well , Dont no if the clutch has ever been done , Car drives spot on and pulls really well through out, so my next ideas were to replace gearbox/clutch fluids and see if it changes anything.
Also if anyone is near to me i would be happy to show them and gain some more knowledge. Thank you all
