I’m having handling issues, it’s hard to describe but it just doesn’t feel as planted as usual. It’s a bit woolly and I swear I can hear a slight grinding noise when I’m parking at low speeds. It almost feels as if I’ve got a flat but I’ve checked and they are spot on.
As I’ve not given you much to go on I’ll give you the back ground.
It started on Thursday I went over a lot of speed bumps in a short distance with a couple of boxes in the boot. These boxes sounded as if they were knocking together when I went over each speed bump so I pulled over to secure them. As I got out I noticed some glass so I made sure I tried to avoid the glass pulling back out. The drive back to the office was uneventful but I thought I’d better check my tyre pressures just in case and they were fine. I checked them again before I set off home for the night and they were again fine.
On my way home it really felt like I had a flat so much so I pulled over three times in total just to check I didn’t. I don’t get wheel wobble and if I let go of the steering wheel it carries on going straight so it doesn’t look like tracking.
I thought it was just in my head after going over the glass but I’ve lost all confidence and I need to do something about it.
Well if you’ve got this far down thank you but can you help? Is there anything I can check or does it look like a costly trip to Honda?
