Headlight adjustment
Hey guys,
Can any one please tell me or illustrate by a picture where the headlight adjuster is on a Facelift ep3
I've seen many guides on the pre facelift with the white cogs.
My level adjuster does work but when Honda installed my bulbs the N/S seems to be off level
Many thanks
On top of the headlight motor there's a small hole with the gear inside. You need a very long screw driver with a Phillips end to put down into this hole and turn.
Same problem here and still dont understand what need to adjust :confused:
Or iam just blind and dont see it
Picture? please :-k:-k
So, I found where to adjust up-down, left right...
Up-down is not problem if you have thin long screwdriver ...
If you look on top side of headlight you will see some small mark up-down. You will see some hole and put screwdriver inside and rotate it on left-right side. Depends what you want, pull it up or down.
Same is for left-right...lots time i spend to see where is adjustment for that and first i take off headlights and yesterday i see it..yes it is so simple...i was blind :/
no need to take off anything XD
still dont know how much to pull up or down :/
