R20190 said:If you have a pre-facelift CTR it will be reverse polarity, i.e. type-B fitting.
Just a tip, install a slightly higher fuse for the HIDs. I think the standards are 15A, install a 20A fuse.
andycole said:R20190 said:If you have a pre-facelift CTR it will be reverse polarity, i.e. type-B fitting.
Cheers mate, i have the neg harness fitted as supplied, just they would like confirmation as they have never had the problem i've got with full beam before.
AC :?
andycole said:The kit is fitted fine and dandy, i'm not sure on the solenoid movement and neither are the suppliers, just that when you go to main beam the light that lit up the road on dipped dissapears leaving 30 ft of darkness in front of the car, like being on sidelights really but in pitch black.
AC
andycole said:Hi mate, i see what you mean but a bit difficult to check without blinding myself, with the lights off the solenoid is in dipped position but you need power and full beam on to move the solenoid to check the capsule position.
AC
R20190 said:andycole said:Hi mate, i see what you mean but a bit difficult to check without blinding myself, with the lights off the solenoid is in dipped position but you need power and full beam on to move the solenoid to check the capsule position.
AC
No you don't. The light does not need to be on to move the glass capsule, in fact, you can move if by hand (gently of course) with gloves or a tissue. (Its basically just a magnet controlling it). As long as you don't touch it with your bare hands you'll be ok. Obviously do this when its cold. :wink:
If you're worried about damaging it, just take my word for it.
