all you need is a 10mm socket and this is easy took me 5 minutes
start by removing plastic trim UNDER your glove box this should just pull out and you will see this.
then remove the plugs going into the ecu be carfull not to pull on the wires or bent or brake the clips or even the pins inside the plugs
then undo the 3 10mm bolts holding the ecu two are below the glove box and one is through the glovebox...remove the glovebox by pushing the sides in then it should drop right down to expose the ecu fully
the ecu will be loose and your done!!!
Sent from my GT-I9300 using Tapatalk 2
