How to replace a broken bonnet release cable
Today I replaced my broken bonnet release cable on my EP3 civic. Seeing as it's a common problem, I thought it might be useful to other owners to write a step by step guide with photos so please feel free to follow the link below if you want to replace the cable yourself:
https://flic.kr/s/aHsm7piv4M
Cheers,
Ben
Good evening! Some nice pics above, but I'm falling at the first hurdle because I can't get the trim cover off!
I can get the trim away from the sill side and prise it away so that I can see the bonnet release cable end bracket, but I can see no way of completely removing the trim without breaking something. There are no visible push pin clips etc. There is a hole in the trim towards the bulkhead but inside I can just feel a bit of bendy plastic.
Can anyone tell me what I am missing?
It looks to me as if, having got the trim off and unbolted the mounting bracket for the cable, it should be pretty simple to use either a left or right type replacement release knob.
Thank you Flashy. I got a bit braver and found that it actually needs to be released from the sill side and then pulled back towards the rear of the car a bit. That releases the captive clips without breaking them. Alloy Bodge Replacement ordered.
Alloy bodge fitted. The whole job was much easier if the cable end support bracket was removed from the sidewall of the footwell. I found the easiest way to trim off the old plastic on the cable end, was to use a junior hack saw. Otherwise entirely straightforward.
