Lambda sensor
Hi guys I have just bought a solid fab manifold will be fitting this Saturday. Do I need to buy a lambda sensor?
Sent from my SM-N910F using Tapatalk
Decat manifold? You'll have a lambda sensor in your OEM manifold that will come out and go in the new manifold, however it will throw an engine management light if there is no cat.
The cheap was round it is an O2 spacer/lambda sensor spacer but this does not correct the AFR changes from fitting the manifold.
The correct way is to get the car remapped properly, which would include turning off secondary lambda sensor monitoring.
You'll be fine then for a few days. Just don't kick its head in quite as much as you normally would. :lol:
