little issue with bc coilovers
ok guys just bought a set of bc br coilovers fitted them with no issues took the car today to quick fit to get a basic geo done they went and adjusted the track road ends etc manged passanger side with no issues but couldnt get the drivers side done due to it running out of adjustment, any idea on how i can fix this, could be be related to the camber topmounts the set is second hand so am asuming the previous owner had camber dialed in but i dont know. any help would be greatful
Move the top mounts into positive camber position.
Use camber bolts on the knuckle to gain negative camber.
Ideally you'll need modified/shortened arms to gain more camber on the top mounts.
cheers for the reply tbh am going for a basic frsu so not to fussed about the camber bolts etc as long as it drives better and the steering wheel is straigh i'll be happy. also where do i get the modded arms from just incase i change my mind
cheers mate as i say its just the drivers side thats run out of threads rather anoying
just regiseterd on the site have to wait for activation
Ι had the same problem and i also know three more ep3s in my country with the same issue.You have to cut the one side steering arm.
