Lowering Help!!
Hi people I'm hoping I could get some advice on this!
I'm thinking about lowering my ep3?? Not to sure how much I should lower it by or how to really go about getting it done! :confused:
Any advice would be great :lol:
Should be lots of info on this.
General is Eibach springs which lower around 20-25mm which are generally considered best for their money. Teins also do the same which i have but these can be a little crashy over bumps.
If lowering also purchase Camber arms & bolts and get a Fast Road Set up as it will benefit the car so much more.
Please do a search on this ALCTR, you will find more info than you can digest :) .
- EIbach Pro-Kit.
- SPC Camber Arms
- SPC Camber Bolts
- FRSU
- Cost: About £400-£450 in total. Unless you can do the work yourself; out-lay for parts will be about £280ish.
[/Generic]
would be good if we could get a forum robot which is programmed to answer certain questions which are asked every other week
Ok thanks for your help and advice! I can get the work done myself so that will save pennies, I'll use the search button first next time *** :) cheers boys! :)
