Hey Guys,
I just took a very nice White JDM EP3 in PX for my S2000. It has a few problems however which Im trying to sort out....
1. The nearside headlight does not work. On taking this out its a HID bulb which are not prone to failing. However, the rear of the light is missing (Bulb cover) and the fuse for the light in the fuse box is a 7.5A one when it should be 15A, so its obv blown before and been replaced incorrectly..... Ive rectified this fuse problem and swapped the relays but still no luck....
What can I do to test weather the bulb is gone, or the actual HID device on the nearside is gone? I cant get at the nearside bulb as its so damn close to the engine mount and I really want to avoid removing the bumper!!!
Ive been told that the discharge unit in HID systems can go... Does it sound like this?
2. The power steering does not work for the first few minutes when the car is cold in the morning. As long as there is some heat left in the car, its fine even on startup, but in the mornings it never works. The car starts and a wierd noise happens under the bonnet and the EPS light comes on. After a mile or so driving it just kicks in and the light goes off. Very frustrating and confussing. Any ideas guys?
Im very impressed with the car tho! Its nice being back in a car your not fighting to stop killing you by throwing you sideways at walls again! You can really boot it and feel safe! The handling on it is brilliant!
Any help you could give on these things would be brilliant!
Adam
Adam
