OEM Airbox Removal - Help!
Hi,
Bought a new induction kit, however to my shock having problems removing the small bolt/screws to remove the lid as the seem sort of seized.
I tried using a screwdriver didnt work and also a drill which didnt, as for the larger bolts actually holding the whole airbox down i cant get access to them.
I noticed there is one large gold bolt on the right and at the back quite a smaller bolt.
I was told i need a socket set and extension, i bought this will this do the job?
http://www.ebay.co.uk/itm/ROLSON-TO...t=UK_Hand_Tools_Equipment&hash=item27c01308fd
you dont have to remove the lid of the Airbox just remove the nuts and bolts around the Airbox. And yes that socket set should do the trick :lol:
I believe there is a bolt on the inside of the airbox to be removed?
Will try WD-40 on the small bolts holding the lid on as they appear rusty and seized.
Biggest concern is that there is enough extension in that wee kit i bought for access to the bolts.
i removed my air box a few days ago mate and there was no bolt inside the airbox that had to be removed from my one?? i never even took the lid off at all :confused:
Even better, so looks like i just have to remove the large gold one on the right and the really small one at the back.
Cheers.
no problem mate its a bit tight getting the box out the engine bay but its easy enough done... good luck !
