(mods feel free to sticky this!)
Okay guys I thought I'd write a quick guide to some pro wiring plugs that you can DIY to an OEM standard . This is ideal for engine bay wiring, interior mods wiring (eg gauges) and ICE wiring. Here I'll be showing you how to make an OEM style plug for a parcel shelf containing 6x9s.
Ok so here we have some 6x9's mounted in my Type-R parcel shelf
I've soldered the wires onto the speakers for security
The problem is, when the shelf is removed, the wiring needs to be split somewhere between the amp and the speaker. If you're a pikey you'll just use spade connectors which work loose after a while and never really come close to being a proper job.
So, take your wiring and strip about 5mm off the end, to suit your new terminals
This is an ideal tool to have, costs about £60 from Vehicle Wiring Products but it takes care of all the crimping side of things
Slide the rubber grommet over the ends of the wires, so it just sits level with the end of the insulation
Here's the terminal we are going to be using, sit the rubber grommet inside the larger clamps and the exposed copper wire in the smaller ones
Then just slide it into the crimping tool
This tool has a ratchet action, so you'll never release it until it's properly done, like this!
The crimped terminals will then simply click into the plugs we are using
The long (male) terminals go into the longer half of the plug
The shorter (female) terminals go into the shorter half of the plug
Make sure the wires correspond on both sides of the plug - eg you're not feeding positive into one side that runs into an earth wire on the other!
And here we have one factory-quality plug. You can really pull on the terminals and they will not come loose! It's also said to be waterproof, which is ideal if you're doing this wiring for a slimline fan or foglights.
I've even used these in my Porsche to connect non-factory wiring to a factory plug, so you can make mods plug n play AND fully reversible without needing to cut wires.
This link is useful for the tools, terminals and plugs you will need. They are well worth a visit in person too as they are very helpful chaps indeed
http://www.vehicle-wiring-products.eu/VWP-onlinestore/home/homepage.php
I hope this is helpful to you all.
