Right chaps, advice needed please
To cut a long and boring story short, would it be advisable to get the centrebore of my wheels professionally opened out to accommodate a larger centrebore hubcentric wheels spacer? I need to take exact measurements but I believe it would be minimal, a couple of mm.
Basically, I need a 5mm spacer to clear the wilwoods and the generic one I have on is not ideal and with only 5mm thickness it is impossible to make a spacer with the same bore as the hub.
Alternatively, to completely bypass this problem, get longer studs fitted and use 10mm spacers. The more I think about it, this is the simpler option. Does anybody know a kind of rough price for getting extended studs fitted? I know the hub needs to come off and the studs need pressed out and in so its a garage job.
All thoughts and ideas appreciated chums
