CTR_Paul said:I read about someone testing both a K20A and K20A2 to destruction, you need to rev at 8800+ for a considerable time to do real damage (unless it's whilst your cornering hard!).
I shouldn't worry.
Livvy + Paul said:Just by unplugging the ecu will not clear any faults stored in the ecu.you will have to plug in a hds tester or scanner to clear the stored fault.
MilanoChris said:CTR_Paul said:I read about someone testing both a K20A and K20A2 to destruction, you need to rev at 8800+ for a considerable time to do real damage (unless it's whilst your cornering hard!).
I shouldn't worry.
It was a right hander. Left handers are the main problem with the K20.
I'll just reset the ECU - should be fine. As for locking the car, it shouldn't matter round here in all honesty.
I shouldn't worry.
MilanoChris said:I over revved the car today during some brisk driving to just short of the 9K mark on a downshift. Car is still fine (had another 10 miles of brisk driving afterwards).
Is it just a case of re setting the ECU and the log of the over rev is gone?
Fire_2 said:i was sure it was left handers, i saw what happens to the engine, at tgm's poor guy did a trackday with low oil easy to see with the sump off
Rcb said:Chris haven't you sold your CTR now :?
