Hi, just bought myself an EP3 facelift, on the test drive and the long drive home there were no issues, the following morning managed to get 2 miles before the temp gauge shot up. Turned the heaters on full blast and nothing but cold air came out, turned the engine off as soon as I could and left it cool down before restarting and coasting it as much as possible home. I don't remember the rad fan coming on at any point. I don't have a code reader to hand, but no EML came up on the dash.
Car is now up on axle stands, oil cap and dipstick is clear of mayo, found a coolant leak on the weep hole on the rad (just below a yellow drain plug), the radiator has very recently been changed im guessing for a cheapy as apparently the last one (original?) was cracked, can't see any other coolant leaks, nothing in the footwells or waterpump area, obviously had to top up the rad to get the coolant level back up. Leaving the engine warm up today, the radiator is stone cold to the touch including the lower and upper radiator pipes.
Not sure what to do and what I need to replace!?! Firstly, why is the rad leaking from the weep hole? Could it be that this is the issue i.e the system isn't pressurising? Is the thermostat stuck closed?
